MARPORT TE NBTE V3 s/n 4239542 932A
Автор: hostmarineoffice | Jan 12, 20
Trawl Eye NBTE V2 s/n 4239542 932A #KM
* CONFIG READ *
  1. FIRM126 : $8.03
  2. FIRM101 : $5.01
  3. FIRM102 : $1.00
  4. UNIQUE ID : $000005C1932A
  5. LOG TIME : $112 s
  6. A1 lock Stat : $No
  7. Down Range : $40 m
  8. Up Range : $20 m
  9. Uplink Freq : $44.000 kHz
  10. Uplink pow : $2200
  11. SD Card rec : $No
  12. SD File ID : $00000000.BIN
  13. Up Sounding : $No
  14. Double Down : $No
  15. Delay Prp : $0 s
  16. Temp Offset : $0.000 Deg C
  17. Temp Scale : $1.000
  18. Pres Offset : $0.100 Bar
  19. Press Scale : $1.000
  20. Roll Offset : $0.000
  21. Option True Mode : $Config1
  22. Protocol : $2
  23. Trawl Opening : $20 m
  24. Ping Up len : $0.3 ms
  25. Ping Down l : $0.3 ms
  26. TVG Up coef : $0.500
  27. TVG Down co : $0.510
  28. ATT Up : $22
  29. ATT Down : $25
  30. VCO Up coef : $3
  31. VCO Down co : $3
  32. F Ping Down : $165.000 kHz
  33. F OL Down : $620.000 kHz
  34. F Ping Up : $165.000 kHz
  35. F OL Up : $620.000 kHz
  36. Down NFloor : $515 mV
  37. Ringing Down Profil : $(0,150)(25,185)(100,72)(200,125)
  38. Up N Floor : $410 mV
  39. Ringing Up Profil : $(0,150)(25,185)(100,72)(200,125)
  40. Orientation : $Vertical
  41. Pres coef a : $1.457692E-03
  42. Pres coef b : $3.236178E-03
  43. Pres coef c : $9.073813E-05
  44. Pres coef d : $6.171406E-07
  45. Pres coef e : $-5.844702E+03
  46. Pres coef f : $5.272567E+00
  47. Pres coef g : $-1.616843E-03
  48. Pres coef h : $1.698110E-07
  49. Pres coef i : $-1.304605E+02
  50. Pres coef j : $1.343032E-01
  51. Pres coef k : $-4.578095E-05
  52. Pres coef l : $5.123563E-09
  53. Pres coef m : $-9.230475E+00
  54. Pres coef n : $9.661617E-03
  55. Pres coef o : $-2.994243E-06
  56. Pres coef p : $3.083636E-10
  57. Pres coef q : $2.124023E-02
  58. Pres coef r : $-2.165388E-05
  59. Pres coef s : $7.314594E-09
  60. Pres coef t : $-8.221269E-13
  61. Pres coef u : $-1.379773E-04
  62. Pres coef v : $1.388848E-07
  63. Pres coef w : $-4.661143E-11
  64. Pres coef x : $5.213705E-15
* CONFIG READ END *
Автор: metanx | Dec 13, 20
11.12.2023 Install O-rings. Sh. bolts. Charging battery s/n 0523-35370;0523-35369.
*** CONFIG READ ***
  1. FIRM126 : $8.03
  2. FIRM101 : $5.01
  3. FIRM102 : $1.00
  5. LOG TIME : $153 s
  8. Up Range : $20 m
  22. Protocol : $2
  28. ATT Up : $22
  29. ATT Down : $25
*** CONFIG READ END ***
Автор: Danila Krivitskii | Mar 01, 20
01.03.2025 Обслужен
Install O-ring’s
